• 48.3 cm (19")
  • SXGA (1280 x 1024 @ 60 Hz)
  • 5 ms (on/off)
  • Widescreen (5:4)
  • 1 VGA
฿6,490.00
จัดส่งฟรี
เงินสดพร้อมจัดส่ง
การจัดส่ง
ตรวจสอบรหัสไปรษณีย์
ระยะเวลาการจัดส่งไปยัง คือ:
สินค้าหมด
ค่าจัดส่งมาตรฐาน: ฟรี
HP ProDisplay P19A 19-inch LED Backlit Monitor
มีสินค้า
D2W67AA
Boost productivity with essential functionality at an affordable price.
Increase optimal viewing and easy readability of software and tools designed for 5:4 aspect ratio presentations – ideal in banking, healthcare, financial, POS, retail and other business environments.
Get compatible with HP accessories.
Free up valuable desk space and take the monitor completely off the desk; the 100-mm standard VESA pattern supports wall or swing arm mounting with the HP Quick Release or HP Monitor Arm (each sold separately).
Get peace of mind.
Stable product lifecycle and minimum one-year lifespan help ensure product consistency across staggered deployments.
Design the screen for how you work.
HP Display Assistant consolidates monitor setting controls into an easy-to-use, centralized interface.
Earn your environmental stripes.
Help reduce your power consumption costs with an intelligent, energy-efficient design built with the environment in mind. Mercury-free LED display backlighting, a low-halogen[3] design and arsenic-free[4] display glass are just a few of the display’s responsible details.
อะไรอยู่ในกล่อง
  • HP ProDisplay P19A 19-inch LED Backlit Monitor
  • VGA cable
  • AC power cable
  • Printed documentation and CD
  • HP DisplayAssistant and Adobe Acrobat Reader software
ข้อมูลจำเพาะ
ข้อมูลมากกว่านี้
หมายเลขผลิตภัณฑ์ D2W67AA
Product color Black
ข้อมูลจำเพาะของจอแสดงผล
Display size (diagonal) 48.3 cm (19")
Aspect ratio Widescreen (5:4)
Resolution (native) SXGA (1280 x 1024 @ 60 Hz)
Pixel pitch 0.294 mm
Brightness 250 cd/m²
Contrast ratio 1000:1 static; 1000000:1 dynamic
View angle 170° horizontal; 160° vertical
Response time 5 ms (on/off)
Tilt and swivel angle Tilt: -5 to +25°
Display features Plug and Play; Anti-glare; User programmable; Language selection; On-screen controls; LED Backlights
อินเตอร์เฟซ
Display Input Type 1 VGA
ขนาดและน้ำหนัก
Dimensions without stand (W x D x H) 41.4 x 5.75 x 34.7 cm
Dimensions with stand (W x D x H) 41.4 x 20.64 x 41.82 cm
น้ำหนัก 3.5 kg
ข้อกำหนดด้านกำลังและการดำเนินงาน
แหล่งจ่ายไฟ Input voltage: 100 to 240 VAC
Power Consumption Description 25 W (maximum), 15 W (typical), 0.5 W (standby)
Operating temperature range 5 to 35°C
ประสิทธิภาพการใช้พลังงานและการรับรอง
Energy Efficiency Compliance ENERGY STAR® qualified; EPEAT® Gold
สิ่งแวดล้อม Arsenic-free display glass; Mercury-free display backlighting; Low halogen; TCO Certified
รายการบรรจุ
อะไรอยู่ในกล่อง HP ProDisplay P19A 19-inch LED Backlit Monitor; VGA cable; AC power cable; Printed documentation and CD; HP DisplayAssistant and Adobe Acrobat Reader software
การรับประกันและการรักษาความปลอดภัย
การประกัน Three years parts, labour and on-site limited warranty
Physical security Security lock ready
  • CLOUD, getReviews, 293.38ms
เปรียบเทียบผลิตภัณฑ์
พนักงานของ HP: รายงานปัญหาเว็บไซต์
