Introducing HP Smart Tank Printers
The Ultimate in Printing Freedom
Explore the features of the new HP Smart Tank series.
High volume colour printing at extremely low cost per page with the World's leading printer vendor.1
Engineered for high-volume, low-cost printing.
Get up to 8,000 colour pages or up to 6,000 black pages.2,3
Get outstanding print quality with the latest technology.
With HP Smart Tank printers, you can print borderless brochures, fade-resistant photos, and other documents – all with dark, crisp text, and vibrant colour.4
Freedom to work from anywhere.
Print and scan from virtually anywhere with the HP Smart App.5 Eliminate steps in repetitive tasks with customizable shortcuts using Smart Tasks.
  • App Store
  • Google Play
Faster connections, easy productivity.
Whether connecting your HP Smart Tank printer to your network or your mobile device to your printer, we have you covered. Get faster, more reliable connections with dual band Wi-Fi®.6
Choose the right HP Smart Tank Printer for your business.
  1. Center facing
    HP Smart Tank 515 Wireless All-in-One
    High-quality ink tank printing with faster connections[2] and easy mobile printing.[3]
    • Functions: Print, scan, copy, wireless
    • Print Speed (Black): Up to 22 ppm
    • Apple AirPrint™; Google Cloud Print™; HP ePrint; Mopria™; Wireless (Wi-Fi®); Wireless direct printing; Bluetooth
    • Ink tank system; Print from mobile device; Scan to PDF
    ฿5,590.00
    Out of Stock (Delivery may take up to 2-3 weeks) or Notify Me when it's available
  2. Center facing
    HP Smart Tank 615 Wireless All-in-One
    High-quality ink tank printing – faster connections,[2] easy mobile printing,[3] and fax.
    • Functions: Print, copy, scan, fax, ADF, wireless
    ฿6,990.00
    In Stock (Dispatch within 2-3 days)
  3. Center facing
    HP Smart Tank 500 All-in-One
    High-quality, high-capacity ink tank printing with all-in-one versatility.
    • Product color: Light Basalt
    • USB
    • Ink tank system; Scan to PDF
    ฿4,410.00
Simple, spill-free refill.
HP's unique ink tank system gives you easy, convenient, mess-free refills with resealable bottles.
SHOP NOW
  1. Based on IDC Worldwide Quarterly Hardcopy Peripherals Tracker®, 2018 Q4 for shipments of all printing devices (inkjet printers, laser printers, copiers and multifunction devices, including production units).
  2. Based up on 200 pages per month usage. Actual yield varies considerably based on content of printed pages and other factors. Average based on ISO/IEC 24711 or HP testing methodology and continuous printing. Some ink from included bottles is used to start up the printer. For details see www.hp.com/go/learnaboutsupplies.
  3. Black and composite colour average per bottle (cyan/magenta/yellow) Two 32XL (EMEA DM) GT53XL (LAR) black bottles included in the box print up to 6000 test pages each. Results based on HP methodology and continuous printing of ISO/IEC 24712 test pages. Not based on ISO/IEC 24711 test process. An additional black ink bottle may be required to print 8000 colour test pages. Actual yield varies based on content of printed pages and other factors. Some ink from included bottles is used to start up the printer. For more information about fill and yield, see: www.hp.com/go/learnaboutsupplies.
  4. Excludes first set of ISO test pages. For details, see hp.com/go/printerclaims.
  5. Requires the HP Smart app download. For details on local printing requirements see hp.com/go/mobileprinting.
  6. Wireless operations are compatible with 2.4 GHz and 5.0 GHz operations only. Learn more at hp.com/go/mobileprinting. Wi-Fi is a registered trademark of Wi-Fi Alliance®. Supports both 5.0 GHz and 2.4 GHz using up to 12 non-overlapping channels vs only 3 non-overlapping channels for 2.4 GHz only. Supports 5.0 GHz band (up to 150 mbps) vs 2.4 GHz band (up to 72.2 mbps).
