Terima kasih telah mengunjungi INDONESIA Toko HP
Senin-Jumat 09.00 - 18.00
(kecuali hari libur)
No. of Payments | Minimum Pemesanan | Maksimum Pemesanan | |||
Periode | 3X | 6X | |||
Bulan | Rp 693.333 | Rp 346.667 | Rp 500.001 | Rp 19.999.999 | |
Bulan | Rp 693.333 | Rp 355.680 | Rp 500.001 | Rp 19.999.999 |
*These computations are estimates. Minimum spend and other fees may apply. Info lebih lanjut
Biaya Bunga:
Min. Batas Pemesanan:
Tidak ada
Rp10.000 / Hingga Rp10 juta
Biaya Bunga:
Tidak ada
Mastercard / Visa / America Express / JCB / Setoran Langsung / Transfer Bank / Tunai saat Pengiriman
Enjoy business-class brightness, contrast, and clarity in a 21.5-inch diagonal monitor that's easy on the wallet.
Place this sleek, affordable design that complements HP desktops and notebooks wherever you need it. The internal power supply helps keeps your desk tidy.
Get crisp, clear views of your content and plenty of room to multi-task with 1920 x 1080 resolution, 1M:1 dynamic contrast ratio, and 5 ms response time on a 21.5-inch inch diagonal screen.[1] Easily connect to your devices with VGA and DVI inputs.
Rest assured that your IT investment is supported by a one- or three-year standard limited warranty.[2] To extend your protection, select optional HP Care Pack Services.[3]
Spesifikasi
Ukuran Layar
21.5-inch
Resolution (native)
FHD (1920 x 1080 @ 60 Hz)
Response time
5 ms on/off
Special offers
Produk Purchase-With-Purchase |
Dapatkan tambahan 20% diskon untuk Aksesoris disini** |
Dapatkan tambahan 10% diskon untuk Monitor disini** |
Dapatkan tambahan 10% diskon untuk Printer disini** |
Driver, Manual & Dukungan
fitur
TECHNICAL DETAILS
Price is inclusive of 11% VAT (where applicable).
Kami ingin menggunakan input data Anda untuk membantu meningkatkan pengalaman berbelanja Anda. Apakah Anda ingin membagikan data online Anda (seperti kode pin lokasi) untuk mendapatkan pengalaman pelanggan yang lebih baik?
