• Display size (diagonal)49.53 cm (19.5")
  • Resolution (native)HD+ (1600 x 900 @ 60 Hz)
  • Response time5 ms on/off
  • Aspect Ratio16:9
  • Input connector1 VGA
Hanya tersisa 0
Rp 1.640.000
Ingin Perawatan Produk *? Info lebih lanjut
Please call 007-803-331-5068 (toll free) for more information or Contact Us
Gratis Pengiriman
Delivery
Periksa ketersediaan di
Perkiraan pengiriman ke :
Kehabisan persediaan
HP V201 19.45-inch LED Backlit Monitor
E6W38AA
Affordable, stylish, and compact.
Get a stylish and budget-friendly design that complements HP PCs and has a small footprint that leaves plenty of room on the desk. The internal power supply also helps keep your workspace tidy.
Business-class content presentation in an efficient screen size.
Step up to a 19.45-inch diagonal screen that offers ample screen space for everything you do every day.
Adjustable positioning.
Make yourself comfortable with adjustable tilt settings.
Designed with the environment in mind and backed by HP support.
Be a better environmental consumer with a monitor that has arsenic-free display glass and mercury-free display backlights.
Apa yang ada di dalam kotak
  • Monitor
  • AC power cable
  • VGA cable
  • Printed documentation and CD
  • HP Display Assistant software
Spesifikasi
Informasi lebih lanjut
Nomor produk E6W38AA
Product color Black
Spesifikasi Tampilan
Display size (diagonal) 49.53 cm (19.5")
Aspect ratio 16:9
Resolution (native) HD+ (1600 x 900 @ 60 Hz)
Resolutions supported 1600 x 900; 1440 x 900; 1280 x 1024; 1280 x 720; 1024 x 768; 800 x 600; 720 x 400; 640 x 480
Pixel pitch 0.27 mm
Brightness 200 cd/m²
Contrast ratio 600:1 static; 3000000:1 dynamic
View angle 90° horizontal; 50° vertical
Response time 5 ms on/off
Tilt and swivel angle Tilt: -5 to +15°
Onscreen controls Menu; Minus ("-"); Plus ("+") /Source; OK/Auto; Power
Display features Plug and Play; Anti-glare; User programmable; Language selection; On-screen controls; LED Backlights
Antarmuka
Display Input Type 1 VGA
Dimensi dan Berat
Dimensions without stand (W x D x H) 46.8 x 4.69 x 28.82 cm
Dimensions with stand (W x D x H) 46.8 x 19 x 35.52 cm
Berat 2.8 kg
Kebutuhan daya dan operasi
Catu daya Input voltage: 90 to 265 VAC
Power Consumption Description 20 W (maximum), 18 W (typical), 0.5 W (standby)
Operating temperature range 5 to 35°C
Efisiensi dan sertifikasi energi
Lingkungan Mercury-free display backlights; Arsenic-free display glass
Certifications and compliances CB; ETL; S-mark; NOM; FCC; ICES
Daftar kemasan
Apa yang ada di dalam kotak Monitor; AC power cable; VGA cable; Printed documentation and CD; HP Display Assistant software
Garansi dan Keamanan
Jaminan 3 years parts, labour and on-site limited warranty
Physical security Security Lock-ready
Kesesuaian
Aksesoris HP LCD Monitor Quick EM870AA; HP Business PC Security Lock Kit PV606AA; HP Single Monitor Arm BT861AA; HP Adjustable Dual Display Stand AW664AA
5% Diskon dengan pembelian Laptop/Desktop
  • CLOUD, getReviews, 478.21ms
Membandingkan Produk
  • Tambahkan
    Produk
  • Bandingkan sekarang
    Kosongkan Semua
Pilih Toko
Karyawan HP: Laporkan masalah di situs web
