• Display size (diagonal)60.45 cm (23.8")
  • Resolution (native)2560 x 1440 @ 60 Hz
  • Response time5 ms gray to gray
  • Aspect Ratio16:9
  • Input connector1 HDMI (with HDCP support); 1 MHL (with HDCP support); 1 DisplayPort™ 1.2 (with HDCP support)
Hanya tersisa 0
MRP Rp 8.199.000
Rp 7.750.000
Hemat: Rp 449.000 (5%)
Ingin Perawatan Produk *? Info lebih lanjut
Please call 007-803-331-5068 (toll free) for more information or Contact Us
Gratis Pengiriman
Delivery
Periksa ketersediaan di
Perkiraan pengiriman ke :
Kehabisan persediaan
It’s wireless, powerful, gorgeous, and sounds fantastic. It’s like nothing you’ve ever experienced.
HP EliteDisplay S240uj 23.8-inch USB-C Wireless Charging Monitor
T7B66AA
Get charged up to meet the demands of your business day…and night
Just set your phone or tablet on the base of HP’s first fully integrated wireless charging display to charge on contact while you work, so at day’s end, it’s ready to go when you are. No cables needed!
Conquer your clutter with USB-C™
Redefine your “clean desk policy.” With just a single USB-C™ cable, connect your PC, notebook, tablet or phone to the high resolution 23.8-inch diagonal display for video, audio, USB data, and power.[1] It’s really that simple.
Supersize your productivity
See up to 77% more in extraordinary detail with Quad HD.[2] Expand your view, open more windows, and show content from multiple devices simultaneously with picture-in-picture and picture-by-picture.
Brace yourself for office envy
Break the sound barrier with integrated premium Audio by Bang & Olufsen that makes your calls and videos pop, and grab attention on all sides with a beautiful micro-edge design.
Even more connections for everything you use
Set your phone or tablet on the base of HP’s first fully integrated wireless charging display while you work, so it’s ready to go when you are.
Redefine your “clean desk policy” when you connect a PC, notebook, tablet or phone to the high resolution 23.8-inch diagonal display with just a single USB-C™ connection.
See up to 77% more[2], expand your view, open more windows, and show content from multiple devices with Quad HD, PiP, and PbP.
  • Integrated speakers Integrated speakers are built-in speakers that come ready inside an electronic device, such as laptop.
  • IPS panel In-plane Switching (IPS) panel is a screen technology in display gives you wide viewing angle of up to 178-degree.
  • LED backlighting Reduced energy consumption, offer better contrast and brightness, and greater color range instead of cold cathode fluorescent (CCFL) backlighting.
  • Widescreen Widescreen computer display offers more viewable space, and are typically of the 16:9 or 16:10 aspect ratio.
Apa yang ada di dalam kotak
  • Monitor
  • AC power cord
  • HDMI cable
  • MHL cable
  • USB cable
  • USB Type-C™ cable
  • DP cable
  • CD (includes User Guide, warranty, drivers)
  • HP Display Assistant software
Spesifikasi
Informasi lebih lanjut
Nomor produk T7B66AA
Product color Silver
Display type IPS w/LED Backlight
Spesifikasi Tampilan
Display size (diagonal) 60.45 cm (23.8")
Display area (metric) 525.67 x 295.7 mm
Aspect ratio 16:9
Resolution (native) 2560 x 1440 @ 60 Hz
Resolutions supported 2560 x 1440; 1920 x 1200; 1920 x 1080; 1680 x 1050; 1600 x 1200; 1600 x 900; 1440 x 900; 1366 x 768; 1280 x 1024; 1280 x 960; 1280 x 800; 1280 x 768; 1280 x 720; 1024 x 768; 720 x 480; 800 x 600; 720 x 400; 640 x 480
Pixel pitch 0.20535 mm
Brightness 300 cd/m²
Contrast ratio 1000:1 static; 5000000:1 dynamic
View angle 178° horizontal; 178° vertical
Response time 5 ms gray to gray
Tilt and swivel angle Tilt: -5 to +21°
Onscreen controls Menu; Minus ("-"); Color Control; Exit; Next Input; Power; Swap USB Host
Display features Anti-glare; In plane switching; Language selection; LED Backlights; On-screen controls; Plug and Play; User programmable; Asset Control; Anti-static; User controls
Antarmuka
Display Input Type 1 HDMI (with HDCP support); 1 MHL (with HDCP support); 1 DisplayPort™ 1.2 (with HDCP support)
Ports 3 USB 3.0 (one upstream, two downstream); 1 USB Type-C™ (two downstream and two upstream ports [1B + 1C]); 1 audio output
External I/O ports footnote [1] All specifications represent the typical specifications provided by HP's component manufacturers, actual performance may vary either higher or lower.
Multimedia Audio input with integrated 2 W per channel speakers; B&O certified
Dimensi dan Berat
Dimensions without stand (W x D x H) 54.06 x 4.43 x 34.6 cm
Dimensions with stand (W x D x H) 54.06 x 21.34 x 42.9 cm
Berat 5.5 kg
Kebutuhan daya dan operasi
Catu daya Input voltage: 100 to 240 VAC
Power Consumption Description 148 W (maximum), 40 W (typical), 0.5 W (standby)
Operating temperature range 5 to 35°C
Efisiensi dan sertifikasi energi
Lingkungan Arsenic-free display glass; Mercury-free display backlights; Low halogen
Environmental specification footnote number [2] External power supplies, power cords, cables and peripherals are not Low Halogen. Service parts obtained after purchase may not be Low Halogen.
Certifications and compliances CE; CB; MSIP; Mexico CoC; ICES; TUV-S; TUV Bauart; ISO 9241-307; EAC; CSA; ISC; CCC; CEL; CECP; SEPA; VCCI; FCC; BSMI; Vietnam MEPS; Australian-New Zealand MEPS; WEEE; Microsoft WHQL Certification Win-10, Win-8, Win-7
Daftar kemasan
Apa yang ada di dalam kotak Monitor; AC power cord; HDMI cable; MHL cable; USB cable; USB Type-C™ cable; DP cable; CD (includes User Guide, warranty, drivers); HP Display Assistant software
Garansi dan Keamanan
Jaminan 3 years parts and labour limited warranty.
Physical security Security lock-ready (lock is sold separately)
Kesesuaian
Aksesoris HP Business PC Security Lock Kit - PV606AA
5% Diskon dengan pembelian Laptop/Desktop
  • CLOUD, getReviews, 255.42ms
Membandingkan Produk
  • Tambahkan
    Produk
  • Bandingkan sekarang
    Kosongkan Semua
Pilih Toko
Karyawan HP: Laporkan masalah di situs web
