• Display size (diagonal)20"
  • Resolution (native)1600 x 900
  • Response time5 ms (on/off)
  • Aspect RatioWidescreen (16:9)
  • Input connector1 DisplayPort (with HDCP support); 1 DVI-D (with HDCP support); VGA
Hanya tersisa 0
Rp 2.420.000
Ingin Perawatan Produk *? Info lebih lanjut
Please call 007-803-331-5068 (toll free) for more information or Contact Us
Gratis Pengiriman
Delivery
Periksa ketersediaan di
Perkiraan pengiriman ke :
Kehabisan persediaan
HP EliteDisplay E201 20-inch LED Backlit Monitor
C9V73AA
Enhance your view, advance your connectivity
Get vibrant text and graphics from the LED backlit panel, which also makes the monitor thin, light, and easy to position on a desk.
Get comfortable with HP’s ultimate adjustable design
Find your most comfortable working position so you can power through your day. Customizable tilt, height adjustment, swivel, and pivot settings—the most adjustability available on an HP business display—help you find your sweet spot.
Control your environmental impact
Reduce power consumption and help lower your costs with an intelligent, energy efficient design that carries ENERGY STAR®, EPEAT® Gold[2], and TCO certifications.
Global reassurance
Rest assured that your IT investment is supported by a three-year standard limited warranty. Select optional HP Care Pack Services[5] to extend your protection beyond the standard warranties.
Apa yang ada di dalam kotak
  • HP EliteDisplay E201 20-inch LED Backlit Monitor
  • VGA cable
  • DVI-D cable (for APJ region only)
  • DisplayPort cable (not included in APJ region except for Australia and New Zealand)
  • USB cable
  • AC power cable
  • Printed documentation and CD
  • HP DisplayAssistant software
Spesifikasi
Informasi lebih lanjut
Nomor produk C9V73AA
Product color Black
Spesifikasi Tampilan
Display size (diagonal) 20"
Aspect ratio Widescreen (16:9)
Resolution (native) 1600 x 900
Pixel pitch 0.276 mm
Brightness 250 cd/m²
Contrast ratio 1000:1 static; 5000000:1 dynamic
View angle 170° horizontal; 160° vertical
Response time 5 ms (on/off)
Tilt and swivel angle Tilt: -5 to +30°; Swivel: 360°
Display features Plug and Play; Anti-glare; User programmable; Language selection; On-screen controls
Antarmuka
Display Input Type 1 DisplayPort (with HDCP support); 1 DVI-D (with HDCP support); VGA
Ports 3 USB 2.0 (one upstream, two downstream)
Dimensi dan Berat
Dimensions without stand (W x D x H) 47.28 x 5.1 x 28.9 cm
Dimensions with stand (W x D x H) 47.28 x 22.89 x 43.48 cm
Berat 5.2 kg
Kebutuhan daya dan operasi
Catu daya Input voltage: 90 to 265 VAC
Power Consumption Description 30 W (maximum), 22 W (typical), 0.5 W (standby)
Operating temperature range 5 to 35°C
Efisiensi dan sertifikasi energi
Energy Efficiency Compliance ENERGY STAR® qualified; EPEAT® Gold
Lingkungan Arsenic-free display glass; Mercury-free display backlighting; Low halogen
Daftar kemasan
Apa yang ada di dalam kotak HP EliteDisplay E201 20-inch LED Backlit Monitor; VGA cable; DVI-D cable (for APJ region only); DisplayPort cable (not included in APJ region except for Australia and New Zealand); USB cable; AC power cable; Printed documentation and CD; HP DisplayAssistant software
Garansi dan Keamanan
Jaminan Three years parts, labour and on-site limited warranty
Physical security Security lock ready
5% Diskon dengan pembelian Laptop/Desktop
  • CLOUD, getReviews, 501.11ms
  • bvseo-msg: Error - Operation timed out after 500 milliseconds with 0 bytes received; HTTP status code of 0 was returned;
Membandingkan Produk
  • Tambahkan
    Produk
  • Bandingkan sekarang
    Kosongkan Semua
Pilih Toko
Karyawan HP: Laporkan masalah di situs web
