• Color
  • 2 Hi-Speed USB 2.0 Host; 1 Hi-Speed USB 2.0 Device; 1 Gigabit Ethernet 10/100/1000T Network; 1 Foreign Interface; 1 Hardware Integration Pocket (HIP); 2 Internal USB Host; 1 Fax
  • Laser
  • One-year onsite warranty
Hanya tersisa 0
Rp 100.000.000
Ingin Perawatan Produk *? Info lebih lanjut
Please call 007-803-331-5068 (toll free) for more information or Contact Us
Gratis Pengiriman
Delivery
Periksa ketersediaan di
Perkiraan pengiriman ke :
Kehabisan persediaan
This top-of-the-line enterprise MFP helps streamline workflows and accelerate document tasks—with advanced finishing options and file sharing. Give users simple, direct access to this MFP through mobile printing and touch-to-print capabilities.[6]
HP Color LaserJet Enterprise flow MFP M880z+ NFC/Wireless Direct
D7P71A
Let departments scan without worry. HP EveryPage detects potential errors or missed pages on the spot.
Save on both sides—capture documents faster with two-sided, single-pass scanning.
Mobile printing at a touch—enable touch-to-print convenience from mobile devices.[1]
  • Functions: Print, copy, scan, fax
  • HP ePrint; Wireless direct printing; Ethernet networking; USB; Wireless optional (with accessory)
  • Automatic document feeder; Flow; Front USB flash drive port; Scan to email; Scan to PDF; Touchscreen; Two-sided printing; Two-sided scanning; Print from mobile device
  • Automatic document feeder Automatic document feeder (ADF) allows user to print, scan or copy quickly without having to manually putting paper into the machine.
  • Flow Designed to accelerate business workflow and complete high-volume jobs with high-speed performance.
  • Front USB flash drive port The USB flash drive port is located in front of the device for easy accessibilty.
  • Print from mobile device This printer works with wireless connectivity and can be used to print from mobile devices.
  • Scan to email Scan your documents and send them directly to your email through wireless connection.
  • Scan to PDF Scan your paper document from your scanner to PDF file using Adobe Acrobat.
  • Touchscreen Touchscreen enables you to interact directly with what is displayed with your finger.
  • Two-sided printing Double-sided printing is available with this printer
  • Two-sided scanning Double-sided scanning is available with this scanner.
Apa yang ada di dalam kotak
  • HP Color LaserJet Multifunction Printer
  • Black, Cyan, Magenta, and Yellow HP Color LaserJet Drums
  • Black, Cyan, Magenta, and Yellow HP Color LaserJet Toner Cartridges
  • CD with software drivers and documentation
  • Documentation (Hardware Install Guide)
  • power cord
  • HP Jetdirect Gigabit Ethernet Print Server (embedded)
  • 100-sheet multipurpose tray 1
  • 500-sheet input tray 2
  • Automatic duplexer (built-in)
  • Encrypted Hard Drive: 3500 high capacity sheet paper input
  • Fax
  • Fax cable
  • NFC/direct print kit
Persediaan yang dapat dipesan
HP LaserJet Transfer and Roller Kit D7H14A, HP Color LaserJet 110Volt Fuser Kit C1N54A, HP Color LaserJet 220Volt Fuser Kit C1N58A, HP ADF Roller Replacement Kit C1P70A, HP Stapler Cartridge Refill C8091A, HP 2-pack 2000-staple Cartridge CC383A
Spesifikasi
Informasi lebih lanjut
SKU D7P71A
Mencetak
Print speed, black 41 - 50
Color or black Color
Print speed, color 41 - 50
Kategori
Product types Laser printers
Family brand LaserJet Enterprise
Usage
Perfect for Enterprise
Usage Department
fitur
fitur Automatic document feeder, Flow, Front USB flash drive port, Print from mobile device, Scan to email, Scan to PDF, Touchscreen, Two-sided printing, Two-sided scanning
Fungsi Print scan copy and fax
Kecepatan Cetak
Print speed duplex (letter) Up to 43 ipm
Print speed duplex (A4) Up to 43 ipm
Print speed black (normal, tabloid) Up to 22 ppm
Print speed color (normal, tabloid) Up to 22 ppm
Print speed colour (normal, A3) Up to 22 ppm
Print speed color (normal, letter) Up to 45 ppm
Print speed black (normal, letter) Up to 45 ppm
Print speed colour (normal, A4) Up to 46 ppm
Print speed Print speed up to 46 ppm (black) and 46 ppm (color)
Print speed black (normal, A4) Up to 46 ppm
Print speed black (normal, A3) Up to 22 ppm
Salin Kecepatan
Copy speed black duplex (Letter) Up to 43 ipm
Copy speed color duplex (Letter) Up to 43 ipm
Copy speed color duplex (A4) Up to 43 ipm
Copy speed black duplex (A4) Up to 43 ipm
Copy speed black (normal, letter) Up to 45 cpm
Copy speed color (normal, letter) Up to 45 cpm
Copy speed note First Copy Out and Copy Speed measured using ISO/IEC 29183, excludes first set of test documents. For more information see hp.com/go/printerclaims. Exact speed varies depending on the system configuration, software application, driver, and document complexity.
Copy speed (black, normal quality, A4) Up to 46 cpm
Copy speed (colour, normal quality, A4) Up to 46 cpm
Penanganan Media Cetak
Paper handling output, optional Stapler/Stacker, Stapler/Stacker with 2/4 Hole Punch, Booklet Maker, Booklet Maker with 2/4 Hole Punch, Booklet Maker with 2/3 Hole Punch
Envelope input capacity Up to 10 envelopes
Finished output handling Sheet feed; Staple; hole punch; fold; fold and stitch (only available with an optional finisher attached)
Standard output capacity (transparencies) Up to 100 sheets
Maximum input capacity (sheets) Up to 4100 sheets (75 g/m² media)
Standard output capacity (envelopes) Up to 60 envelopes
Paper handling output, standard 500-sheet face-down bin
Input capacity Up to 4100 sheets (75 g/m² media)
Paper handling input, standard 100-sheet multipurpose tray, 500-sheet input tray, 1500-sheet input tray, 2000-sheet input tray
Media type and capacity, ADF Sheets: 200 (20 lb, 75 g/m²)
Media type and capacity, tray 2 Sheets: 500 (75 g/m²)
Media type and capacity, tray 1 Sheets: 100 (75 g/m²); Envelopes: 10
Media type and capacity, tray 3 Tray 3: Sheets: 1500 (75 g/m²); Tray 4: Sheets: 2000 (75 g/m²)
Maximum output capacity (sheets) Up to 3000 sheets (75 g/m² media) with an optional output device.
Output capacity Up to 500 sheets (75 g/m² media)
Kecepatan Pindai
Scan speed duplex (normal, A4) Up to 85 ipm (b&w), up to 63 ipm (color)
Scan speed duplex (normal, letter) Up to 85 ipm (b&w), up to 63 ipm (color)
Scan speed (normal, letter) Up to 70 ppm (b&w), up to 68 ppm (color)
Scan speed (normal, A4) Up to 70 ppm (b&w), up to 68 ppm (color)
Waktu Cetak
First page out color (letter, ready) As fast as 8 sec
First page out color (letter, sleep) As fast as 18 sec
First page out black (letter, sleep) As fast as 18 sec
First page out black (letter, ready) As fast as 8 sec
First page out black (A4, ready) As fast as 8 sec
First page out color (A4, ready) As fast as 8 sec
Spesifikasi Pengirim Digital
Digital sending optional features Optional via HP Digital Sending Software (HP DSS); Send to folder; Send-to-workflow; Send-to-printer; Authentication; Digital fax (send to LAN, Internet); OCR; Local Address Book; via HP Embedded Capture; Metadata capture and validation; Data transfer; Scan workflow management
Digital sending standard features Scan to e-mail; Save-to-Network Folder; Scan to SharePoint; Save-to-USB drive; Send to FTP; Send to LAN Fax; Send to Internet Fax; OCR; Local Address Book; SMTP over SSL
File formats, supported Digital Send: PDF, JPEG, TIFF, MTIFF, XPS, PDF/A, TEXT (OCR), Unicode TEXT (OCR), RTF (OCR), Searchable PDF (OCR), Searchable PDF/A (OCR), HTML (OCR), CSV (OCR); Scan to easy access USB: PDF, JPEG, TIFF, MTIFF, XPS, PDF/A, TEXT (OCR), Unicode TEXT (OCR), RTF (OCR), Searchable PDF (OCR), Searchable PDF/A (OCR), HTML (OCR), CSV (OCR); Print from easy access USB: PDF, PS, Print Ready files (.prn, .pcl, .cht)
Spesifikasi Scanner
Scan technology Charge Coupled Device (CCD)
Recommended monthly scan volume 26,750 to 44,600
Scan size (ADF), maximum 297 x 432 mm
Duplex ADF scanning Yes, single pass duplexing ADF
Bit Depth 24-bit
Scan size ADF (minimum) 147 x 68 mm
Scan input modes Copy, scan-to-email, scan to network folder, scan to USB, save to device
Levels of grayscale 256
Scan size, maximum 297 x 432 mm
Scanner type Flatbed, ADF
Auto document feeder capacity Standard, 200 sheets (20 lb, 75 g/m²)
Color scanning Yes
Scan file format Digital Send: PDF, JPEG, TIFF, MTIFF, XPS, PDF/A, TEXT (OCR), Unicode TEXT (OCR), RTF (OCR), Searchable PDF (OCR), Searchable PDF/A (OCR), HTML (OCR), CSV (OCR); Scan to easy access USB: PDF, JPEG, TIFF, MTIFF, XPS, PDF/A, TEXT (OCR), Unicode TEXT (OCR), RTF (OCR), Searchable PDF (OCR), Searchable PDF/A (OCR), HTML (OCR), CSV (OCR); Print from easy access USB: PDF, PS, Print Ready files (.prn, .pcl, .cht)
Kesesuaian
Orderable supplies HP LaserJet Transfer and Roller Kit D7H14A, HP Color LaserJet 110Volt Fuser Kit C1N54A, HP Color LaserJet 220Volt Fuser Kit C1N58A, HP ADF Roller Replacement Kit C1P70A, HP Stapler Cartridge Refill C8091A, HP 2-pack 2000-staple Cartridge CC383A
Aksesoris HP LaserJet Booklet Maker/Finisher A2W83A, HP LaserJet Booklet Maker/Finisher with 2/3 hole punch A2W84A, HP LaserJet Booklet Maker/Finisher with 2/4 hole punch CZ999A, HP LaserJet Stapler/Stacker A2W80A, HP LaserJet Stapler/Stacker with 2/4 hole punch A2W82A, HP LaserJet MFP Analog Fax Accessory 500 CC487A, USB Wireless Print Server J8026A, NFC/Wireless Direct Kit J8029A, HP LaserJet Smpd/Trdl Chns Ovrlys Keybrd A7W12A, HP LaserJet Dnsh/Frnch/Ger Ovrlys Keybrd A7W13A
Nama Produk
Sub-brand name LaserJet
Spesifikasi Faks
Fax memory Incoming fax can be stored to disk
Remote retrieval No
Junk fax barrier Yes, as blocked fax numbers
Faxing Yes
Fax delayed sending No
Broadcast locations 100
Fax forwarding Yes
Polling No
Speed dials, maximum number Up to 100 (each can contain 100 numbers)
Auto redial Yes
PC interface supported Yes, PC fax send only
Fax telephone mode supported No
Distinctive ring detection supported Yes
Telephone handset supported No
Auto fax reduction supported Yes
Multimedia dan Perangkat Input
Resolusi Up to 300 x 600 dpi (ADF), Up to 600 x 600 dpi (flatbed)
Fax phone TAM interface supported No
Sertifikasi dan Kepatuhan
Eco label ENERGY STAR® qualified
Energy Efficiency Compliance ENERGY STAR® qualified
Telecom compliance (fax capability) Fax Telecom: ES 203 021; R&TTE Directive 1999/5/EC (Annex II) with CE Marking (Europe); FCC Part 68; Industry Canada CS03; NOM-151-SCTI-1999 (Mexico); PTC-200 (New Zealand); other Telecom approvals as required by individual countries
Safety Approvals and Requirements IEC 60950-1:2005 +A1; EN60950-1: 2006 +A11:2009 +A1:2010 +A12:2011; IEC 60825-1:2007 (Class 1 Laser/Led Product); EN 60825-1:2007 (Class 1 Laser/LED Product); UL/cUL Listed (USA/Canada); GS Certificate (Germany, Europe); IEC 62479:2010; EN 62479:2010; Low Voltage Directive 2006/95/EC with CE Marking (Europe); other safety approvals as required by individual countries
Electromagnetic Emission Standard CISPR 22:2008 / EN 55022:2010 (Class A), EN 61000-3-2 :2006 +A1:2009 +A2:2009; EN 61000-3-3 :2008; EN 55024:2010; FCC Title 47 CFR, Part 15 Class A(USA); ICES-003, Issue 4 (Canada); EMC Directive 2004/108/EC with CE Marking (Europe); other EMC approvals as required by individual countries
ENERGY STAR® certified Yes
Lingkungan Mercury free
Spesifikasi Tampilan
Display 8" SVGA 800 x 600 dpi resolution capacitive-touch display with gesture support and extended keyboard
Konektivitas dan Komunikasi
HP ePrint capability Yes
Connectivity, optional HP Jetdirect ew2500 802.11b/g Wireless Print Server J8021A; HP Jetdirect 2700w USB Wireless Print Server J8026A
Network ready Standard (built-in Gigabit Ethernet); Included Touch to Print and Wireless Direct
Ports 1 Hi-Speed device USB 2.0; 2 Host USB 2.0 (for third party connections); 1 Jetlink; 1 Accessory (for Kensington Lock); 1 Gigabit ethernet 10/100/1000; 1 Fax; 1 FIH
Connectivity, standard 2 Hi-Speed USB 2.0 Host; 1 Hi-Speed USB 2.0 Device; 1 Gigabit Ethernet 10/100/1000T Network; 1 Foreign Interface; 1 Hardware Integration Pocket (HIP); 2 Internal USB Host; 1 Fax
Network capabilities Yes, via HP Jetdirect Ethernet embedded print server (standard) which supports: 10Base-T, 100Base-Tx, 1000Base-T; 802.3az (EEE) support on Fast Ethernet and Gig Links; IPsec (standard); 802.11b/g/n wireless networking (optional). Please note: HP Jetdirect 2800W (J8029A) and HP Jetdirect 2700W (J8026A) accessories cannot be installed at the same time.
Wireless capability Yes, built-in Gigabit Ethernet; Included Touch to Print and Wireless Direct
Network protocols, supported IPv4/IPv6: Apple Bonjour Compatible (Mac OS 10.2.4 and later), SNMPv1/v2c/v3, HTTP, HTTPS, FTP, Port 9100, LPD, IPP, Secure-IPP, WS Discovery, IPsec/Firewall;IPv6: DHCPv6, MLDv1, ICMPv6; IPv4: Auto-IP, SLP, TFTP, Telnet, IGMPv2, BOOTP/DHCP, WINS, IP Direct Mode, WS Print;Other: IPX/SPX, AppleTalk, NetWare NDS, Bindery, NDPS, iPrint
Mobile printing capability HP ePrint; Wireless Direct Printing
Fitur lanjutan
Energy savings feature technology HP Auto-on/Auto-off Technology; Instant-on Technology
Fax smart software features Stored faxes; fax archiving; fax forwarding; scale-to-fit; fax address book; LAN/Internet fax; fax number confirmation; Holiday fax schedule
Scanner advanced features Optimize text/picture; Image adjustments; Job build; Output quality setting; Selectable scan resolution 75 to 600 dpi; Auto detect color; Edge erase; Auto tone; Auto job notification; Blank page suppression; Auto orientation; Auto page crop; HP Quick Sets
Copier smart software features Auto scale; Reduce/enlarge from scanner glass (25 to 400 %); Collate; Auto color detection; Two-sided copying; Image adjustments (darkness, background cleanup, sharpness); Job build; Offset; Staple, booklet making, hole punch
Printer smart software features HP ePrint, Apple AirPrint™, Mopria-certified, Open Extensibility Platform, FutureSmart Firmware, Instant-on Technology, HP Auto-On/Auto-Off Technology, HP Easy Color, Pantone© Calibrated, print preview, duplex, print multiple pages per sheet (2, 4, 6, 9, 16), collation, watermarks, store print jobs, job separator, staple, offset, booklet making, hole punch
Lingkungan
Acoustic power emissions (active copy) 7.2 B(A)
Recommended operating temperature range 15 to 30ºC
Storage temperature range 0 to 35ºC
Operating humidity range 10 to 80% RH
Acoustic power emissions 7.0 B(A)
Non-Operating Humidity Range 10 to 90% RH
Acoustic pressure emissions bystander (active, printing) 54 dB(A)
Acoustic power note Configurations tested included color and mono printing, simplex and duplex printing, and 110 VAC and 220 VAC units at 46 ppm.
Operating temperature range 15 to 30ºC
Acoustic power emissions (active scan) 7.0 B(A)
Acoustic power emissions (ready) 5.0 B(A)
Acoustic pressure emissions bystander (ready) 33 dB(A)
Baterai dan Daya
Power supply type Built-in power supply
Power Consumption Description 972 watts (Printing), 972 watts (Copying), 80 watts (Ready), 8.0 watts (Sleep), 1.2 watt (Auto-Off), 0.4 watts (Off)
Catu daya 110-volt input voltage: 110 to 127 VAC (+/- 10%), 60 Hz (+/- 2 Hz), 10.5 A; 220-volt input voltage: 220 to 240 VAC (+/- 10%), 50 Hz (+/- 2 Hz), 5.5 A (Not dual voltage, power supply varies by part number with # Option code identifier)
Media Percetakan yang Didukung
Media types Cut sheet paper, labels, transparencies, glossy paper, glossy film, photo media, tough paper, envelopes
Media weight, supported Tray 1, 2: 60 to 220 g/m²; Tray 3, 4: 60 to 120 g/m²
Standard media sizes (duplex) A3; A4; A4-R; B5 (JIS); B4 (JIS); RA3; SRA3; RA4; SRA4; 216 x 340 mm; 8K (270 x 390 mm), 8K (260 x 368 mm), 8K (273 x 394 mm), 16K (195 x 270 mm), 16K (184 x 260 mm), 16K (197 x 273 mm)
Media size, tray 2 A3, A4, A4-R, A5, B5 (JIS), B4 (JIS), RA4, SRA4, 8K (270 x 390), 8K (260 x 368), 8K (273 x 394), 16K (195 x 270), 16K (184 x 260), 16K (197 x 273)
Media size, tray 1 A3, A4, A4-R, A5, B5 (JIS), B4 (JIS); RA4, SRA4, 8K (270 x 390), 8K (260 x 368), 8K (273 x 394), 16K (195 x 270), 16K (184 x 260), 16K (197 x 273), RA3, SRA3, A6, B6 (JIS), photo 2L, Dpostcard (JIS); Envelopes: B5, C5, C6, DL
Media size, tray 3 A4-L, LTR-L
Media sizes supported Tray 1: A3, A4, A4-R, A5, B5 (JIS), B4 (JIS), RA4, SRA4, 8K (270 x 390), 8K (260 x 368), 8K (273 x 394), 16K (195 x 270), 16K (184 x 260), 16K (197 x 273); RA3, SRA3, A6, B6 (JIS), Photo 2L, DPostcard (JIS); Envelopes: B5, C5, C6, DL; Tray 2: A3, A4, A4-R, A5, B5 (JIS), B4 (JIS), RA4, SRA4,8K (270 x 390), 8K (260 x 368), 8K (273 x 394), 16K (195 x 270), 16K (184 x 260), 16K (197 x 273); Trays 3+: A4
Recommended media weight (duplex) 60 to 220 g/m²
Media weight (tray 2) 60 to 220 g/m²
Media weight (tray 1) 60 to 220 g/m²
Media weight (tray 3) Tray 3, 4: 60 to 120 g/m²
Media weights, supported, ADF 45 to 199 g/m²
Media size (ADF) B6 (JIS); A5; B5 (JIS); Letter; A4; Legal 13" (Officio); Legal 14"; B4; Ledger (11 x 17 in); A3
Media sizes supported, key 10 x 15 cm; A4; A3; Envelopes
Media sizes supported, key 4 x 6 in; Letter; Legal; 11 x 17 in; Envelopes
Media sizes, custom Tray 1: 76.2 x 127 to 320 x 457.2 mm; Tray 2: 148 x 210 to 297 x 432 mm; Tray 3, 4: 210 x 297 mm
Kecepatan Faks
Fax note Based on standard ITU-T test image #1 at standard resolution and MMR encoding, the HP fax device can transmit at 3 sec/page for V.34 and 6 sec/page for V.17
Fax transmission speed 33.6 kbps
Fax transmission speed 3 sec per page
Isi kotak
Cable included No, please purchase USB cable separately
Ingatan
Memory slots 1 slot, 200-pin, DDR2 DIMM
Memory, maximum 2.5 GB (system memory)
Ingatan 2.5 GB (system memory)
Memory upgrade Not expandable
Resolusi Pindai
Scan Resolution, Optical Up to 600 dpi
Scan Resolution, Hardware Up to 600 x 600 dpi
Prosesor
Processor speed 800 MHz
Geografis
Country of origin Made in China; Mexico (#AC4; #AC8; #201; #AAZ; #BGJ)
Perangkat Lunak dan Aplikasi
Mac compatible Yes
Downloadable software Basic Color Match; Enterprise installer utility; Linux Driver; Mac CD image; Plug and Play bundles; Smart Web Printing In-House Marketing; Universal Print Driver for Windows; Unix Driver; Web JetAdmin; Windows CD image
Driver updates Latest drivers for supported operating systems are available at: In the US, go to http://www.hp.com/support/colorljflowMFPM880; Outside the US, go to http://www.hp.com/support. Select your country/region. Select Drivers & Downloads. Enter a product name/number. Select your product, select your driver language, select your operating system, under Download, select Drivers or Firmaware. If no access to the Internet, see the install notes on the CD that came in the printer box.
Software included HP PCL 6 Discrete Printer Driver; Mac SW Link to Web (Mac Installer); Windows Installer
Resolusi Faks
Resolution (black and white, superfine mode) 300 x 300 dpi, 256 levels of gray
Fax resolution black 200 x 200 dpi, 256 levels of gray
Resolution (black and white, standard mode) 100 x 100 dpi
Fax resolution Up to 300 x 300 dpi
Persyaratan sistem
Minimum System Requirements Windows 10, Windows 8, Windows 7 SP1+, Windows Vista, Windows Server 2003 (SP1+), Windows Server 2008, Windows Server 2008 R2 (64 bit), Windows Server 2012 (64-bit), Windows XP (SP2+); CD-ROM or DVD drive, or Internet connection; Dedicated universal serial bus (USB 1.1 or 2.0), or network connection; 200 MB available hard disk space; Operating system compatible hardware system requirements see http://www.microsoft.com
Minimum System Requirements for Macintosh Mac OS X v10.6.8, OS X 10.7.5 Lion, OS X 10.8 Mountain Lion; 1 GB of available hard-disk space; CD-ROM or DVD drive, or Internet connection; Dedicated universal serial bus (USB 1.1 or 2.0), or network connection (Operating system compatible hardware system requirements see apple.com)
Bobot
Berat 152.9 kg
Package weight 175.33 kg
Spesifikasi Printer
Envelope feeder No
Duty cycle note Duty cycle is defined as the maximum number of pages per month of imaged output. This value provides a comparison of product robustness in relation to other HP LaserJet or HP Color LaserJet devices, and enables appropriate deployment of printers and MFPs to satisfy the demands of connected individuals or groups.
Duty cycle (monthly, letter) Up to 200,000 pages (print)
Multitasking supported Yes
Storage device and direct print support Front-facing USB/Flash drive; USB printing
Printer management HP Web Jetadmin; HP Utility (Mac)
Automatic paper sensor Yes
Fonts and typefaces 105 internal TrueType fonts scalable in HP PCL, 92 internal scalable fonts in HP Postscript level 3 emulation (Euro symbol built-in); 1 internal Unicode Fonts (Andale Mono WorldType); 2 Internal Windows Vista 8 Fonts (Calibri, Cambria); additional font solutions available via third-party flash memory cards; HP LaserJet Fonts and IPDS Emulation available at hp.com/go/laserjetfonts
Target user and print volume For teams over 25 users; Prints up to 25,000 pages/month
Top key features 200-sheet ADF; Front-facing USB printing; Scan to email/PDF; Two-sided printing
Print colours Yes
Fungsi Print, copy, scan, fax
Internal Storage Standard, minimum 320 GB HP High-Performance Secure Hard Disk (AES 256 hardware encryption or greater)
Print languages HP PCL 6, HP PCL 5, HP postscript level 3 emulation, PDF
Paper trays, maximum 4
Duty cycle (monthly, A4) Up to 200,000 pages
Paper trays, standard 4
Recommended monthly page volume 5000 to 25,000
Print technology Laser
Duplex printing Automatic (standard)
Kartrid dan Printheads
Number of print cartridges 4 (1 each Cyan, Magenta, Yellow, Black)
Technology Laser
Replacement cartridges HP 827A Black LaserJet Toner Cartridge (29,500 pages) CF300A; HP 827A Cyan LaserJet Toner Cartridge (32,000 pages) CF301A; HP 827A Yellow LaserJet Toner Cartridge (32,000 pages) CF302A; HP 827A Magenta LaserJet Toner Cartridge (32,000 pages) CF303A; HP 828A Black LaserJet Imaging Drum (30,000 pages) CF358A; HP 828A Cyan LaserJet Imaging Drum (30,000 pages) CF359A; HP 828A Yellow LaserJet Imaging Drum (30,000 pages) CF364A; HP 828A Magenta LaserJet Imaging Drum (30,000 pages) CF365A
Komponen sistem
Control panel 8.0-in (20.3 cm) color LCD with Capacitive touchscreen; rotating (adjustable angle) display; illuminated Capacitive Home button (for quick return to the Home menu); Easy Access USB; Hardware Integration Pocket
Jaminan
Jaminan One-year onsite warranty
Resolusi Cetak
Print quality color (best) Up to 1200 x 1200 dpi
Print quality black (best) Up to 1200 x 1200 dpi
Print quality black (normal) Up to 600 x 600 dpi
Spesifikasi Copier
Copier settings Sides; Collate; Paper Selection; Color/Black; Reduce/Enlarge; Image Adjustment; Content Orientation
Copier scaling (ADF) 25 to 400%
Copy reduce / enlarge settings 25 to 400%
Copies, maximum Up to 9999 copies
Manajemen keamanan
Security management Identity management: Kerberos authentication, LDAP authentication, 1000 user PIN codes, optional HP and 3rd party advanced authentication solutions (e.g., badge readers); Network: IPsec/firewall with Certificate, Pre-Shared Key, and Kerberos authentication, Supports WJA-10 IPsec configuration Plug-in, 802.1X authentication (EAP-PEAP, EAP-TLS), SNMPv3, HTTPS, Certificates, Access Control List; Data: Storage Encryption, Encrypted PDF & Email (uses FIPS 140 validated cryptographic libraries from Microsoft), Secure Erase, SSL/TLS (HTTPS), Encrypted Credentials; Device: Security lock slot, USB port disablement, hardware integration pocket for security solutions; Security management: Compatible with HP Imaging and Printing Security Center
Sistem Operasi yang Didukung
Operating system (supported note) Windows Installer has the same Operating System support as the printer driver except the following: Windows XP (SP3 or higher) (32-bit only); Windows Server 2003 (SP2 or higher) (32-bit only); Windows Vista Starter not supported in Driver nor Installer; HP Software Installer CD for Windows - The HP PCL 6 discrete driver and .NET 3.5 SP1 are installed for Windows operating systems along with other optional software. .NET 4.0 is included in Windows 8/Server 2012; HP Software for Mac is no longer included on the CD, but can be downloaded from hp.com - the Mac driver and Mac Utility are installed for Mac operating systems.
Compatible network operating systems Windows 8.1 (32-bit/64-bit); Windows 8 Basic (32-bit/64-bit); Windows 8 Pro (32-bit/64-bit); Windows 8 Enterprise (32-bit/64-bit); Windows 8 Enterprise N (32-bit/64-bit); Windows 8 Enterprise RT (32-bit only); Windows 7 (32-bit/64-bit) (Including Starter Edition); Windows Vista (32-bit) (Including Starter Edition); Windows Vista (64-bit); Windows XP (SP2 or higher) (32-bit/64-bit); Windows Server 2012 R2; Windows Server 2012 (No Software Installer support); Windows Server Win7/2008 R2 (SP1); Windows Server 2008 (Standard Edition); Windows Server 2008 (Enterprise Edition); Windows Server 2008 (32-bit/64-bit) (SP1); Windows Server 2008 (32-bit/64-bit) (SP2); Windows Server 2008 R2 (32-bit/64-bit) (Standard Edition, Enterprise Edition); Windows Server 2008 Server Terminal Services; Windows Server 2008 Server Terminal Services with Citrix XenApp; Windows Server 2003 (Standard Edition); Windows Server 2003 (Enterprise Edition); Windows Server 2003 (32-bit/64-bit) (SP1); Windows Server 2003 (32-bit/64-bit) (SP2); Windows Server 2003 R2 (32-bit/64-bit) (Standard Edition, Enterprise Edition); Windows Server 2003 Server Terminal Services; Windows Server 2003 Server Terminal Services w/Citrix Metaframe XP with Feature Release 3; Windows Server 2003 Server Terminal Services w/Citrix Presentation Server 4.0; Windows Server 2003 Server Terminal Services with Citrix Presentation Server 4.5; Novell NetWare 6; Novell NetWare 6.5 [SP8 minimum for full Windows Vista, Windows 7 and Windows XP (SP7 if only Windows XP)]; Novell Novell iPrint Client v5.4 for Windows XP, Windows Vista and Windows 7, (x86 and x64); Novell Novell iPrint Support Only; Novell Novell Open Enterprise Server 2 (Linux); Novell Novell Open Enterprise Server 6.5; Other Citrix (Print): Citirx XenApps 6.0, Xen Server 5.6, Xen Desktop 5.5; Other Cluster Support; Mac 10.5; Mac 10.6.8; Mac 10.7.5; Mac 10.8.x; Mac 10.9.x; For Linux OS versions, refer to the HP Linux web site: hplipopensource.com/hplip-web/index.html; Unix HPUX 11i; IBM AIX 3.2.5 or higher; MPE-iX; Citrix MetaFrame Server; Red Hat Linux 7.x or higher; Solaris 2.5 or higher (SPARC systems only); SuSe Linux 8.x or higher. (For Microsoft IPv6 compatibility use Windows 2003, Windows XP Home, Windows XP Professional and Windows Vista)
Compatible Operating Systems Windows 10 (32-bit/64-bit), Windows 8 (32-bit/64-bit), Windows 7 (32-bit/64-bit), Windows Vista (32-bit/64-bit), Windows XP (SP2 or higher) (32-bit/64-bit), Windows Server 2012 (64-bit), Windows Server 2008 (32-bit/64-bit), Windows Server 2008 R2 (64-bit), Windows Server 2003 (SP1 or higher) (32-bit/64-bit), Mac OS X version 10.6.8, 10.7.5 Lion, 10.8 Mountain Lion. For the latest operating system support see: Air Print (http://support.apple.com/kb/ht4356); Android (http://www.android.com/); Citrix and Windows Terminal Services (http://www.hp.com/go/upd); HP ePrint Software Driver (http://www.hp.com/go/eprintsoftware); Linux (http://www.hplip.net); Novell (http://www.novell.com/iprint); SAP device types (http://www.hp.com/go/sap/drivers); SAP Print (http://www.hp.com/go/sap/print); UNIX (http://www.hp.com/go/unix); UNIX JetDirect (http://www.hp.com/go/jetdirectunix_software)
Spesifikasi Rak dan Daya
Typical electricity consumption (TEC) number 5.83 kWh/Week
Number of users Over 25 Users
Jasa
Services (Care Pack) U8D13E - HP 2 year Next Business day printer Hardware Support; U8D14A - HP 3 year Next Business day printer Hardware Support; U8D14E - HP 3 year Next Business day printer Hardware Support; U8D15E - HP 4 year Next Business day printer Hardware Support; U8D16E - HP 5 year Next Business day printer Hardware Support; U8D17E - HP 3 year 4 hour 9x5 printer Hardware Support; U8D18E - HP 3 year 4 hour 13x5 printer Hardware Support; U8D19E - HP 4 year 4 hour 9x5 printer Hardware Support; U8D20E - HP 4 year 4 hour 13x5 printer Hardware Support; U8D21E - HP 5 year 4 hour 9x5 printer Hardware Support; U8D22E - HP 5 year 4 hour 13x5 Hardware Support; U8D23E - HP 3 year Next Business day + Disk Media Retention printer Support; U8D24E - HP 4 year Next Business day + Disk Media Retention printer Support; U8D25E - HP 5 year Next Business day + Disk Media Retention printer Support; U8D26E - HP 3 year Next Business day + max 3 Maintenance Kit Replacement Service Support; U8D27E - HP 4 year Next Business day + max 4 Maintenance Kit Replacement Service Hardware Support; U8D28E - HP 5 year Next Business day + Max 5 Maintenance Kit Replacement Service Support; U8D29E - HP 3 year Next Business day Channel Remote and Parts Exchange Service; U8D30E - HP 4 year Next Business day Channel Remote and Parts Exchange Service; U8D31E - HP 5 year Next Business day Channel Remote and Parts Exchange Service; U8D32E - HP 3 year Next Business day Call to Repair with Disk Media Retention Hardware Support; U8D33E HP 4 year Next Business day Call to Repair with Disk Media Retention Hardware Support; U8D34E HP 5 year Next Business day Call to Repair with Disk Media Retention Hardware Support; U8D35E - HP 3 year 2nd Business day Call to Repair with Disk Media Retention Hardware Support; U8D36E - HP 4 year 2nd Business day Call to Repair with Disk Media Retention Hardware Support; U8D37E - HP 5 year 2nd Business day Call to Repair with Disk Media Retention Hardware Support; U8D38PA - HP 1 year Post Warranty Next Business day printer Hardware Support; U8D38PE - HP 1 year Post Warranty Next Business day printer Hardware Support; U8D39PE HP 2 year Post Warranty Next Business day printer Hardware Support; U8D40PE HP 1 year Post Warranty 4 hour 9x5 printer Hardware Support; U8D41PE - HP 1 year Post Warranty 4 hour 13x5 printer Hardware Support; U8D42PE - HP 1 year Post Warranty Next Business day + Disk Media Retention Hardware Support; U0LV8PE - HP 1 year Post Warranty Channel Remote and Parts Exchange Service; U0LV9PE - HP 1 year Post Warranty Next Business day Call to Repair with Disk Media Retention Service; U0LW0PE - HP 1 year Post Warranty 2nd Business day Call to Repair with Disk Media Retention Service; U0LW1PE - HP 1 year Post Warranty Next Business day + max 3 Maintenance Kit Replacement Service
Bidang Cetak
Left margin (A4) 2.1 mm
Bottom margin (A4) 2.1 mm
Top margin (A4) 2.1 mm
Right margin (A4) 2.1 mm
Maximum print area 312 x 457.2 mm
Ukuran
Maximum dimensions (W x D x H) 1000 x 800 x 1199 mm
Dimensions without stand (W x D x H) 704 x 635 x 1199 mm
Package dimensions (W x D x H) 856 x 790 x 1567 mm
  • CLOUD, getReviews, 274.09ms
  • [1] Touch-to-print capability is standard in the HP Color LaserJet Enterprise flow MFP M880z+ D7P71A model, and may be added as an option to the HP Color LaserJet Enterprise M880z+ A2W76A and M880z A2W75A. Mobile device must support near-field communications-enabled printing. For a list of supported devices, see hp.com/go/mobileprinting
Membandingkan Produk
  • Tambahkan
    Produk
  • Bandingkan sekarang
    Kosongkan Semua
Pilih Toko
Karyawan HP: Laporkan masalah di situs web
