- 48.3 cm (19")
- SXGA (1280 x 1024 @ 60 Hz)
- 5 ms (on/off)
- Widescreen (5:4)
Check availability at
Product number | D2W67AA |
Product color | Black |
Display Specifications | |
Display size (diagonal) | 48.3 cm (19") |
Aspect ratio | Widescreen (5:4) |
Resolution (native) | SXGA (1280 x 1024 @ 60 Hz) |
Pixel pitch | 0.294 mm |
Brightness | 250 cd/m² |
Contrast ratio | 1000:1 static; 1000000:1 dynamic |
Response time | 5 ms (on/off) |
Display features | Plug and Play; Anti-glare; User programmable; Language selection; On-screen controls; LED Backlights |
Connectivity | |
Display Input Type | 1 VGA |
Dimensions and Weight | |
Dimensions without stand (W x D x H) | 41.4 x 5.75 x 34.7 cm |
Dimensions with stand (W x D x H) | 41.4 x 20.64 x 41.82 cm |
Weight | 3.5 kg |
Power and operating requirements | |
Power | Input voltage: 100 to 240 VAC |
Power Consumption Description | 25 W (maximum), 15 W (typical), 0.5 W (standby) |
Operating temperature range | 5 to 35°C |
Energy efficiency and certifications | |
Energy Efficiency Compliance | ENERGY STAR® qualified; EPEAT® Gold |
Environmental | Arsenic-free display glass; Mercury-free display backlighting; Low halogen; TCO Certified |
Environmental specification footnote number | [2] External power supplies, power cords, cables and peripherals are not Low Halogen. Service parts obtained after purchase may not be Low Halogen. |
Warranty and Security | |
Warranty | Three years parts, labour and on-site limited warranty |
Physical security | Security lock ready |
Add
Product -
Compare nowClear allNo product added to compare list
