• Display size (diagonal)60.45 cm (23.8")
  • Resolution (native)2560 x 1440 @ 60 Hz
  • Response time5 ms gray to gray
  • Aspect Ratio16:9
  • Input connector1 HDMI (with HDCP support); 1 MHL (with HDCP support); 1 DisplayPort™ 1.2 (with HDCP support)
Only 0 left
MRP Rp 8.199.000
Rp 7.750.000
You Save: Rp 449.000 (5%)
Want Product Care*? Learn More
Please call 007-803-331-5068 (toll free) for more information or Contact Us
Free Delivery
Delivery
Check availability at
Delivery estimate to is:
Out of stock
It’s wireless, powerful, gorgeous, and sounds fantastic. It’s like nothing you’ve ever experienced.
HP EliteDisplay S240uj 23.8-inch USB-C Wireless Charging Monitor
Out of stock
T7B66AA
Get charged up to meet the demands of your business day…and night
Just set your phone or tablet on the base of HP’s first fully integrated wireless charging display to charge on contact while you work, so at day’s end, it’s ready to go when you are. No cables needed!
Conquer your clutter with USB-C™
Redefine your “clean desk policy.” With just a single USB-C™ cable, connect your PC, notebook, tablet or phone to the high resolution 23.8-inch diagonal display for video, audio, USB data, and power.[1] It’s really that simple.
Supersize your productivity
See up to 77% more in extraordinary detail with Quad HD.[2] Expand your view, open more windows, and show content from multiple devices simultaneously with picture-in-picture and picture-by-picture.
Brace yourself for office envy
Break the sound barrier with integrated premium Audio by Bang & Olufsen that makes your calls and videos pop, and grab attention on all sides with a beautiful micro-edge design.
Even more connections for everything you use
Set your phone or tablet on the base of HP’s first fully integrated wireless charging display while you work, so it’s ready to go when you are.
Redefine your “clean desk policy” when you connect a PC, notebook, tablet or phone to the high resolution 23.8-inch diagonal display with just a single USB-C™ connection.
See up to 77% more[2], expand your view, open more windows, and show content from multiple devices with Quad HD, PiP, and PbP.
  • Integrated speakers Integrated speakers are built-in speakers that come ready inside an electronic device, such as laptop.
  • IPS panel In-plane Switching (IPS) panel is a screen technology in display gives you wide viewing angle of up to 178-degree.
  • LED backlighting Reduced energy consumption, offer better contrast and brightness, and greater color range instead of cold cathode fluorescent (CCFL) backlighting.
  • Widescreen Widescreen computer display offers more viewable space, and are typically of the 16:9 or 16:10 aspect ratio.
What's in the box
  • Monitor
  • AC power cord
  • HDMI cable
  • MHL cable
  • USB cable
  • USB Type-C™ cable
  • DP cable
  • CD (includes User Guide, warranty, drivers)
  • HP Display Assistant software
More Information
Product number T7B66AA
Product color Silver
Display type IPS w/LED Backlight
Display Specifications
Display size (diagonal) 60.45 cm (23.8")
Display area (metric) 525.67 x 295.7 mm
Aspect ratio 16:9
Resolution (native) 2560 x 1440 @ 60 Hz
Resolutions supported 2560 x 1440; 1920 x 1200; 1920 x 1080; 1680 x 1050; 1600 x 1200; 1600 x 900; 1440 x 900; 1366 x 768; 1280 x 1024; 1280 x 960; 1280 x 800; 1280 x 768; 1280 x 720; 1024 x 768; 720 x 480; 800 x 600; 720 x 400; 640 x 480
Pixel pitch 0.20535 mm
Brightness 300 cd/m²
Contrast ratio 1000:1 static; 5000000:1 dynamic
View angle 178° horizontal; 178° vertical
Response time 5 ms gray to gray
Tilt and swivel angle Tilt: -5 to +21°
Onscreen controls Menu; Minus ("-"); Color Control; Exit; Next Input; Power; Swap USB Host
Display features Anti-glare; In plane switching; Language selection; LED Backlights; On-screen controls; Plug and Play; User programmable; Asset Control; Anti-static; User controls
Connectivity
Display Input Type 1 HDMI (with HDCP support); 1 MHL (with HDCP support); 1 DisplayPort™ 1.2 (with HDCP support)
Ports 3 USB 3.0 (one upstream, two downstream); 1 USB Type-C™ (two downstream and two upstream ports [1B + 1C]); 1 audio output
External I/O ports footnote [1] All specifications represent the typical specifications provided by HP's component manufacturers, actual performance may vary either higher or lower.
Multimedia Audio input with integrated 2 W per channel speakers; B&O certified
Dimensions and Weight
Dimensions without stand (W x D x H) 54.06 x 4.43 x 34.6 cm
Dimensions with stand (W x D x H) 54.06 x 21.34 x 42.9 cm
Weight 5.5 kg
Power and operating requirements
Power Input voltage: 100 to 240 VAC
Power Consumption Description 148 W (maximum), 40 W (typical), 0.5 W (standby)
Operating temperature range 5 to 35°C
Energy efficiency and certifications
Environmental Arsenic-free display glass; Mercury-free display backlights; Low halogen
Environmental specification footnote number [2] External power supplies, power cords, cables and peripherals are not Low Halogen. Service parts obtained after purchase may not be Low Halogen.
Certifications and compliances CE; CB; MSIP; Mexico CoC; ICES; TUV-S; TUV Bauart; ISO 9241-307; EAC; CSA; ISC; CCC; CEL; CECP; SEPA; VCCI; FCC; BSMI; Vietnam MEPS; Australian-New Zealand MEPS; WEEE; Microsoft WHQL Certification Win-10, Win-8, Win-7
What's included
What's in the box Monitor; AC power cord; HDMI cable; MHL cable; USB cable; USB Type-C™ cable; DP cable; CD (includes User Guide, warranty, drivers); HP Display Assistant software
Warranty and Security
Warranty 3 years parts and labour limited warranty.
Physical security Security lock-ready (lock is sold separately)
Compatibility
Accessories HP Business PC Security Lock Kit - PV606AA
5% Discount with purchase of Laptops/Desktops
  • CLOUD, getReviews, 306.41ms
