• Display size (diagonal)68.6 cm (27")
  • Resolution (native)FHD (1920 x 1080 @ 60 Hz)
  • Response time7 ms gray to gray
  • Aspect RatioWidescreen (16:9)
  • Input connector1 VGA; 1 DVI-D (with HDCP support); 1 DisplayPort (with HDCP support)
Only 0 left
Rp 4.099.000
Want Product Care*? Learn More
Please call 007-803-331-5068 (toll free) for more information or Contact Us
Free Delivery
Delivery
Check availability at
Delivery estimate to is:
Out of stock
HP EliteDisplay E271i 27-inch IPS LED Backlit Monitor
Out of stock
D7Z72AA
Now see everything.
Get great 178-degree viewing angles and stunning color integrity from In-Plane Switching (IPS) technology that lets you share your screen with everyone in the room.
Power through your day in comfort.
Customizable tilt, height adjustment, swivel, and pivot settings—the most adjustability available on an HP business display—help you find your sweet spot.
Control your environmental impact.
Reduce power consumption and help lower your costs with an intelligent, energy-efficient design that is ENERGY STAR® qualified and EPEAT® Gold registered.[1]
Enhance your view.
Get crisp, clear content and video from the high contrast ratio and fast response time. Easily connect devices with convenient VGA, DVI, and DisplayPort inputs and the integrated USB hub.
Meet your monitor’s new best friend.
Personalize your workspace with resizable screen partitions and work in documents, spreadsheets, and e-mail in separate regions of the screen—at the same time—with HP Display Assistant software.
Breathe easy.
Rest assured that your IT investment is supported by a standard, 3-year limited warranty. Select optional HP Care Pack Services[3] to extend your protection beyond the standard warranties.
What's in the box
  • Monitor
  • VGA cable
  • USB cable
  • DisplayPort cable (for limited APJ countries)
  • AC power cable
  • Printed documentation and CD
  • HP Display Assistant software
More Information
Product number D7Z72AA
Display Specifications
Display size (diagonal) 68.6 cm (27")
Aspect ratio Widescreen (16:9)
Resolution (native) FHD (1920 x 1080 @ 60 Hz)
Pixel pitch 0.311 mm
Brightness 250 cd/m²
Contrast ratio 1000:1 static; 5000000:1 dynamic
View angle 178° horizontal; 178° vertical
Response time 7 ms gray to gray
Tilt and swivel angle Tilt: -5 to +30°; Swivel 360°; Pivot rotation: 90°
Display features Plug and Play; Anti-glare; User programmable; Language selection; On-screen controls; LED Backlights; In plane switching
Connectivity
Display Input Type 1 VGA; 1 DVI-D (with HDCP support); 1 DisplayPort (with HDCP support)
Ports 3 USB 2.0 (one upstream, two downstream)
Dimensions and Weight
Dimensions without stand (W x D x H) 64.2 x 5.22 x 38.73 cm
Dimensions with stand (W x D x H) 64.2 x 27.85 x 53.21 cm
Weight 7.7 kg
Power and operating requirements
Power Input voltage: 100 to 240 VAC
Power Consumption Description 40 W (maximum), 35 W (typical), 0.5 W (standby)
Operating temperature range 5 to 35°C
Energy efficiency and certifications
Environmental Arsenic-free display glass; Mercury-free display backlighting; Low halogen
Certifications and compliances TCO Certified Edge; CE; CB; KC; KCC; NOM; PSB; ICE; TUV-S; CCC; CEL Grade 1; CECP; SEPA; EPA; ISC; VCCI; FCC; Taiwan BSMI
What's included
What's in the box Monitor; VGA cable; USB cable; DisplayPort cable (for limited APJ countries); AC power cable; Printed documentation and CD; HP Display Assistant software
Warranty and Security
Warranty Three years parts, labour and on-site limited warranty
Physical security Security lock ready
5% Discount with purchase of Laptops/Desktops
  • CLOUD, getReviews, 298.52ms
