• 75.8 cm (30")
  • WQXGA (2560 x 1600 @ 60 Hz)
  • 8 ms gray to gray
  • Widescreen (16:10)
  • 1 VGA; 1 DisplayPort (with HDCP support); 1 DVI-D (with HDCP support); 1 HDMI (with HDCP support)
HK$16,380.00
Free Delivery
Delivery
Delivery estimate is:
Maximize productivity in the commercial enterprise with an HP Z Display
HP Z Display Z30i 30-inch IPS LED Backlit Monitor
In stock
D7P94A4#AB4
Say hello to your new power-smart IPS Gen 2 team player
Lower your power consumption[1] and get 100% coverage of sRGB color spaces and 100% coverage of Adobe RGB color spaces from IPS Gen 2 panels.
Designed-in comfort
Find your most comfortable position with an HP-exclusive 4-way adjustable stand and an integrated HP QR2 Quick Release that enables VESA mounting.
Get connected
Enjoy future-ready and legacy connectivity from a range of inputs that include DisplayPort 1.2, DVI, VGA, HDMI 1.4, audio output for an HP Speaker Bar,[3] and four USB 3.0 ports with speeds up to 10x faster than USB 2.0.
Keep it together
Get organized with the integrated cable management clip. Create a clean, compact all-in-one with the optional HP Thin Client Mount Kit[3]. The HP QR2 Quick Release is integrated into the display to enable quick set up, and it’s VESA mountable.
Meet your monitor’s new best friend
Customize your workspace with resizable screen partitions. Work in documents, spreadsheets, and email in separate regions of the screen—at the same time—with HP Display Assistant software.
Breathe easy
Rest assured that your IT investment is supported by a standard, three-year limited warranty. Select optional HP Care Pack Services[6] to extend your protection up to 5 years.
  • Height/Swivel adjustability Monitor with height/swivel adjustability allows for comfort on your neck and eyes.
  • IPS panel In-plane Switching (IPS) panel is a screen technology in display gives you wide viewing angle of up to 178-degree.
  • LED backlighting Reduced energy consumption, offer better contrast and brightness, and greater color range instead of cold cathode fluorescent (CCFL) backlighting.
  • Pivot rotation Monitor pivot refers to the ability to rotate the display, changing the aspect ratio from a widescreen format to a vertically inclined long format.
  • Widescreen Widescreen computer display offers more viewable space, and are typically of the 16:9 or 16:10 aspect ratio.
What's in the box
  • Monitor
  • AC power cord
  • USB cable
  • DisplayPort cable
  • DVI-D cable
  • Documentation CD
  • HP Display Assistant software
More Information
Product number D7P94A4
Product color Black
Display Specifications
Display size (diagonal) 75.8 cm (30")
Aspect ratio Widescreen (16:10)
Resolution (native) WQXGA (2560 x 1600 @ 60 Hz)
Pixel pitch 0.250 mm
Brightness 350 cd/m²
Contrast ratio 1000:1 static; 5000000:1 dynamic
View angle 178° horizontal; 178° vertical
Response time 8 ms gray to gray
Tilt and swivel angle Tilt: -5 to +20°; Swivel: ±45°; Pivot rotation: 90°
Display features Plug and Play; Anti-glare; User programmable; Language selection; On-screen controls; LED Backlights; In plane switching
Connectivity
Display Input Type 1 VGA; 1 DisplayPort (with HDCP support); 1 DVI-D (with HDCP support); 1 HDMI (with HDCP support)
Ports 5 USB 3.0 (one upstream, four downstream)
Multimedia Audio output connector
Dimensions and Weight
Dimensions without stand (W x D x H) 69.03 x 6.63 x 44.98 cm
Dimensions with stand (W x D x H) 69.03 x 26.64 x 60.1 cm
Weight 9.96 kg
Power and operating requirements
Power Input voltage: 100 to 250 VAC
Power Consumption Description 125 W (maximum), 85 W (typical), > 0.5 W (standby)
Operating temperature range 5 to 35°C
Energy efficiency and certifications
Energy Efficiency Compliance ENERGY STAR® qualified; EPEAT® Gold
Environmental Mercury-free display backlighting; Arsenic-free display glass; Low halogen; TCO Certified
Environmental specification footnote number [2] External power supplies, power cords, cables and peripherals are not Low Halogen. Service parts obtained after purchase may not be Low Halogen.
What's included
What's in the box Monitor; AC power cord; USB cable; DisplayPort cable; DVI-D cable; Documentation CD; HP Display Assistant software
Warranty and Security
Warranty 3 years parts and labour limited warranty
Physical security Security Lock-Ready
  • CLOUD, getReviews, 400.49ms
