• 48.3 cm (19")
  • SXGA (1280 x 1024 @ 60 Hz)
  • 5 ms (on/off)
  • Widescreen (5:4)
  • 1 VGA
HK$1,380.00
Want Product Care*? Learn More
Free Delivery
Delivery
HP ProDisplay P19A 19-inch LED Backlit Monitor
In stock
D2W67AA#AB4
Boost productivity with essential functionality at an affordable price.
Increase optimal viewing and easy readability of software and tools designed for 5:4 aspect ratio presentations – ideal in banking, healthcare, financial, POS, retail and other business environments.
Get compatible with HP accessories.
Free up valuable desk space and take the monitor completely off the desk; the 100-mm standard VESA pattern supports wall or swing arm mounting with the HP Quick Release or HP Monitor Arm (each sold separately).
Get peace of mind.
Stable product lifecycle and minimum one-year lifespan help ensure product consistency across staggered deployments.
Design the screen for how you work.
HP Display Assistant consolidates monitor setting controls into an easy-to-use, centralized interface.
Earn your environmental stripes.
Help reduce your power consumption costs with an intelligent, energy-efficient design built with the environment in mind. Mercury-free LED display backlighting, a low-halogen[3] design and arsenic-free[4] display glass are just a few of the display’s responsible details.
  • LED backlighting Reduced energy consumption, offer better contrast and brightness, and greater color range instead of cold cathode fluorescent (CCFL) backlighting.
  • Widescreen Widescreen computer display offers more viewable space, and are typically of the 16:9 or 16:10 aspect ratio.
What's in the box
  • HP ProDisplay P19A 19-inch LED Backlit Monitor
  • VGA cable
  • AC power cable
  • Printed documentation and CD
  • HP DisplayAssistant and Adobe Acrobat Reader software
More Information
Product number D2W67AA
Product color Black
Display Specifications
Display size (diagonal) 48.3 cm (19")
Aspect ratio Widescreen (5:4)
Resolution (native) SXGA (1280 x 1024 @ 60 Hz)
Pixel pitch 0.294 mm
Brightness 250 cd/m²
Contrast ratio 1000:1 static; 1000000:1 dynamic
View angle 170° horizontal; 160° vertical
Response time 5 ms (on/off)
Tilt and swivel angle Tilt: -5 to +25°
Display features Plug and Play; Anti-glare; User programmable; Language selection; On-screen controls; LED Backlights
Connectivity
Display Input Type 1 VGA
Dimensions and Weight
Dimensions without stand (W x D x H) 41.4 x 5.75 x 34.7 cm
Dimensions with stand (W x D x H) 41.4 x 20.64 x 41.82 cm
Weight 3.5 kg
Power and operating requirements
Power Input voltage: 100 to 240 VAC
Power Consumption Description 25 W (maximum), 15 W (typical), 0.5 W (standby)
Operating temperature range 5 to 35°C
Energy efficiency and certifications
Energy Efficiency Compliance ENERGY STAR® qualified; EPEAT® Gold
Environmental Arsenic-free display glass; Mercury-free display backlighting; Low halogen; TCO Certified
What's included
What's in the box HP ProDisplay P19A 19-inch LED Backlit Monitor; VGA cable; AC power cable; Printed documentation and CD; HP DisplayAssistant and Adobe Acrobat Reader software
Warranty and Security
Warranty Three years parts, labour and on-site limited warranty
Physical security Security lock ready
  • CLOUD, getReviews, 500.9ms
  • bvseo-msg: Error - Operation timed out after 500 milliseconds with 0 bytes received; HTTP status code of 0 was returned;
