• 43.18 cm (17")
  • SXGA (1280 x 1024 @ 60 Hz)
  • 5 ms on/off
  • 5:4
  • 1 VGA
HK$1,199.00
Want Product Care*? Learn More
Free Delivery
Delivery
Delivery estimate is:
Solid performance, a 5:4 aspect ratio, and environmental consciousness at an attractive price point.
HP ProDisplay P17A 17-inch 5:4 LED Backlit Monitor
In stock
F4M97AA#AB4
Business-class presentation features.
Get crisp, clear views of your documents and e-mail with 1280 x 1024 resolution and 5 ms response time on a 17-inch diagonal screen.[1] Quickly connect to your devices with a VGA input. Keep your work space tidy with the internal power supply.
Stay the course.
Keep the 5:4 aspect ratio that your business-specific enterprise and public sector applications are designed to work with.
Budget-friendly product stability.
Get a stable product lifecycle and minimum one-year lifespan at a price point that’s easy on your wallet. Be confident in the improved reliability of a monitor that has been through its paces with HP quality standard testing.
Designed with the environment in mind.
Reduce power consumption and lower costs with an energy efficient design that is ENERGY STAR® and TCO qualified and EPEAT® 2019 registered.[2] Includes mercury-free display backlights, low halogen design,[3] and arsenic-free display glass.
HP accessory compatibility.
  • LED backlighting Reduced energy consumption, offer better contrast and brightness, and greater color range instead of cold cathode fluorescent (CCFL) backlighting.
What's in the box
  • Monitor
  • VGA cable
  • AC power cable
  • Printed documentation and DVD
  • HP Display Assistant software
More Information
Product number F4M97AA
Product color Meteorite bezel, black chassis/stand
Display Specifications
Display size (diagonal) 43.18 cm (17")
Aspect ratio 5:4
Resolution (native) SXGA (1280 x 1024 @ 60 Hz)
Resolutions supported 1280 x 1024; 1280 x 800; 1280 x 720; 1024 x 768; 800 x 600; 720 x 400; 640 x 480
Pixel pitch 0.264 mm
Brightness 250 cd/m²
Contrast ratio 1000:1 static
View angle 170° horizontal; 160° vertical
Response time 5 ms on/off
Tilt and swivel angle Tilt: -5 to +25°
Onscreen controls Menu; Minus ("-"); Plus ("+"); Power
Display features Plug and Play; Anti-glare; User programmable; Language selection; On-screen controls; LED Backlights
Connectivity
Display Input Type 1 VGA
Dimensions and Weight
Dimensions without stand (W x D x H) 37.72 x 5.7 x 31.66 cm
Dimensions with stand (W x D x H) 37.72 x 20.63 x 38.72 cm
Weight 3.72 kg
Power and operating requirements
Power Input voltage: 100 to 240 VAC
Power Consumption Description 20 W (maximum), 15.2 W (typical), 0.5 W (standby)
Operating temperature range 5 to 35°C
Energy efficiency and certifications
Energy Efficiency Compliance ENERGY STAR® qualified; EPEAT® Gold
Environmental Mercury-free display backlights; Arsenic-free display glass; Low halogen; TCO Certified
Environmental specification footnote number [2] External power supplies, power cords, cables and peripherals are not low halogen. Service parts obtained after purchase may not be low halogen.
What's included
What's in the box Monitor; VGA cable; AC power cable; Printed documentation and DVD; HP Display Assistant software
Warranty and Security
Warranty 3 years parts, labour and on-site limited warranty
Physical security Security Lock-ready
Compatibility
Accessories USB Graphics Adapter – dual output C5U89AA; USB Graphics Adapter – single output NL571AA; Single Monitor Arm BT861AA; Speaker Bar NQ576AA; HP LCD Monitor Quick Release EM870AA; HP Business PC Security Lock Kit PV606AA
  • CLOUD, getReviews, 267.68ms
