【HP o2o 】 Exclusive Service
  • 48 cm (18.9")
  • SXGA (1280 x 1024 @ 60 Hz)
  • 8 ms gray to gray
  • 5:4
  • 1 VGA; 1 DVI-D; 1 DisplayPort
HK$1,780.00
Free Delivery
Delivery
HP EliteDisplay E190i 18.9-inch LED Backlit IPS Monitor
In stock
E4U30AA#AB4
The legacy friendly, business-critical IPS display. Get a 5:4 aspect ratio display designed for all of your business-specific applications, now with the impeccable presentation and extra-wide viewing angles of IPS technology. Enjoy customizable comfort from a completely adjustable stand and be environmentally responsible with designed-in energy efficiency.
Now see everything.
Get great 178-degree viewing angles and stunning color integrity from In-Plane Switching (IPS) technology. Accurately view sharp images and consistent color from almost any angle—with less distortion than conventional TN (Twisted Nematic) panels.
Stay the course.
Keep the 5:4 aspect ratio that your business-specific enterprise and public sector applications are designed to work with. Enjoy ample space for all your tasks on the 18.89-inch diagonal screen.
Power through your day in comfort.
Find your most comfortable viewing position with customizable tilt, height adjustment, swivel, and pivot settings.
Help control your environmental impact.
Reduce power consumption and help lower your costs with an intelligent, energy efficient design that’s ENERGY STAR® qualified and EPEAT® 2019 registered.[1]
Performance and connectivity.
Get crisp, clear content and video from the high 3M:1 dynamic contrast ratio and fast response time.[3]
Productivity and management software.
Personalize your workspace with resizable screen partitions and work in documents, spreadsheets, and e-mail in separate regions of the screen—at the same time—with HP Display Assistant software.
Global HP service and support.
Rest assured that your IT investment is supported by a standard, three-year limited warranty.
  • Height/Swivel adjustability
  • IPS panel
  • LED backlighting
  • Pivot rotation
What's in the box
  • Monitor
  • VGA cable
  • DisplayPort cable (select regions)
  • USB cable
  • Warranty card and CD
  • Monitor driver (ICM/INF)
  • Auto adjustment pattern utility software
  • Adobe Acrobat Reader software
  • HP Display Assistant software
More Information
Product number E4U30AA
Product color Black
Display Specifications
Display size (diagonal) 48 cm (18.9")
Aspect ratio 5:4
Resolution (native) SXGA (1280 x 1024 @ 60 Hz)
Resolutions supported 1280 x 1024; 1280 x 800; 1024 x 768; 800 x 600; 720 x 400; 640 x 480
Pixel pitch 0.2928 mm
Brightness 250 cd/m²
Contrast ratio 1000:1 static; 3000000:1 dynamic
View angle 178° horizontal; 178° vertical
Response time 8 ms gray to gray
Tilt and swivel angle Tilt: -5 to +25°; Swivel: ±180°; Pivot rotation: 90°
Onscreen controls Menu; Minus ("-"); Plus ("+"); OK; Power
Display features Plug and Play; Anti-glare; Anti-static; Asset Control; User programmable; Language selection; On-screen controls; LED Backlights; In plane switching
Connectivity
Display Input Type 1 VGA; 1 DVI-D; 1 DisplayPort
Ports 3 USB 2.0 (one upstream, two downstream)
Dimensions and Weight
Dimensions without stand (W x D x H) 41.7 x 4.7 x 34.7 cm
Dimensions with stand (W x D x H) 41.7 x 19.2 x 48.6 cm (at full height)
Weight 4.9 kg
Power and operating requirements
Power Input voltage: 100 to 240 VAC
Power Consumption Description 28 W (maximum), 25 W (typical), < 0.5 W (standby)
Operating temperature range 0 to 40°C
Energy efficiency and certifications
Energy Efficiency Compliance ENERGY STAR® qualified; EPEAT® Gold
Environmental Mercury-free display backlights; Arsenic-free display glass; Low halogen
What's included
What's in the box Monitor; VGA cable; DisplayPort cable (select regions); USB cable; Warranty card and CD; Monitor driver (ICM/INF); Auto adjustment pattern utility software; Adobe Acrobat Reader software; HP Display Assistant software
Warranty and Security
Warranty 3 years parts, labour and on-site limited warranty
Physical security Security Lock-ready
Compatibility
Accessories HP LCD Speaker Bar NQ576AA; HP LCD Monitor Quick Release EM870AA; HP USB Graphics Adapter NL571AA; HP Business PC Security Lock Kit PV606AA; HP DVI to DVI cable DC198A
Rated 5 out of 5 by from Clean compact design I purchased two monitors a month ago -- clean compact design. Trust HP quality.
Date published: 2020-05-07
Rated 5 out of 5 by from Meet my expectation I bought this monitor because I wanted a monitor with wider height than that of Notebook computers. And thi s
Date published: 2018-06-13
  • y_2020, m_8, d_7, h_15
  • bvseo_bulk, prod_bvrr, vn_bulk_3.0.10
  • cp_1, bvpage1
  • co_hasreviews, tv_0, tr_2
  • loc_en_HK, sid_E4U30AA_bv35_AB4, prod, sort_[SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_hpapj-en_hk
  • CLOUD, getReviews, 345.44ms
Contact Us
Support
Stores
